Go Back   California Association of Sunbeam Tiger Owners Forum > Tiger Technical - Personalized/Modified > Engine
New Threads
Reply
Thread Tools Display Modes
  #11
Old 08-26-2017, 09:21 AM
spmdr spmdr is offline
Bronze Forum Member
Member of C.A.T.
Default S&S made headers for CAT...
...starting in the early '90s. The redesigned headers have larger 1 5/8 tubes and most headers have merged (multi-part welded) collectors. CAT stopped using S&S when they moved from CA to AZ.
  #12
Old 08-27-2017, 06:56 AM
gregory schumacher gregory schumacher is offline
Bronze Forum Member
Member of C.A.T.
Default S&S headers
Headers fit car previous owner beat them cant see why because we have no clearance issues. They flow well with the pounding 420RWHP.
  #13
Old 08-27-2017, 07:22 AM
66TigerMK1A's Avatar
66TigerMK1A 66TigerMK1A is offline
Platinum Forum Member
Member of C.A.T.
Default
Quote:
My 'club' headers also fit with zero massaging required... can't say that for the 'J.C. Whitney's ' a P.O. had installed
Click image for larger version
Name:	old headers.jpg
__________________
B382ooo446
TAC # 0671
  #14
Old 08-27-2017, 11:17 AM
Warren's Avatar
Warren Warren is offline
Administrator
Member of C.A.T.
Default I have
A set on my black car they have a bracket tag that is near the collector. Fit is okay but always had a little noise generating rub on motor mounts. Rather then mess with it I expect a Tiger to growl a little
  #15
Old 09-17-2017, 09:21 PM
norm1 norm1 is offline
Gold Forum Member
Member of C.A.T.
Default
Fitting my CAT headers now.
Passenger side fits pretty good but the drivers side has required grinding both motor mounts in 4 places and numerous on and offs. Now have paper thin clearances in 4 spots so next it will be massaging 3 down pipes. Have 2+ hours in it so far with maybe a couple more to go............Need a little extra roon for the external ceramic coating to come...
Reports later in the week.
__________________
'67 MK II
  #16
Old 09-18-2017, 02:19 PM
Gold Forum Member
Member of C.A.T.
Default
Worked 2 hours this morning on the drivers side for clearance to the engine hangers.
Heat and beat #6 tube 2 places, and # 7 tube 2 places in addition to grinding the engine hanger in 3 places.
Passenger side was a quicky, just 1 place on the #2 tube.
Now hopefully a test fit in the engine compartment soon to check for interference there before the trans. gets bolted up.
__________________
'67 MK II
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
