What have you done for the PCV system on the engine if anything?
On my recent 2000 mile trip I had quite an issue with oil being blown out the oil filler cap (had to clean it every gas stop). I also found out Sunday that my bell housing is full of oil again
, getting past the rear main I think.
So I start the engine and zip tie a rubber glove over the oil fill tube to see if any air is entering the engine. Not only is it not entering but the glove gets blown up like a balloon. I pull the PCV valve out of the VC and the glove immediately deflates. I them pull off the PCV and stick the tube from the manifold straight into the VC....the glove is then just about sucked into he VC.
So, I must have the wrong PCV valve. I get a 1992 5.0 Mustang PCV and install it. Now at idle, the oil fill tube has a vacuum that increases with throttle.
I hope this solves my rear main leak now that the crank case has vacuum and not pressure pushing oil past the RM.
Here are some more thoughts. I have one vacuum fitting on the intake manifold and none on the carb. The PCV line is T-ed off for the brake booster and cruise control. The line is 1/2". I am wondering if a dedicated 1/2" fitting should be installed into the manifold just for the PCV. I could then run a 5/8" line vs. the 1/2".
