cadreamn67
Platinum Forum Member
So i left them alone for today and closed the shop. One more thing and i would just do something stupid.
Regards from gemany,
Thibaut
Per your comment above, I would say you are wise beyond your years! I have wished many times I would have had the wisdom to do that.
As for the tie rod ends, they are probably somewhat rusted in the tapered steering arm hole after all these years. I would suggest trying to soak the area with some sort of penetrating oil for a day of so. Just in case it would do any good. Then I would give some really hard whacks to the steering arm tip where the tie rod fits into it. You want to hit the the steering arm part of the conection, not the tie rod part. It should pop apart.
There is also a tool we have over here that is called a pickle fork. It is like a two pronged wedge with a long handle. You drive the prongs in between the steering arm and the tie rod end. My success with such a tool is not all that great however. After all these years you are going to want to replace the tie rod ends any way so don't worry about ruining them. They are probably no good now anyway.
If worse comes to worst, you can always just remove the steering arms from the spindles (two bolts each side) and remove the entire assembly. Put it on a work table to work on later. You will probably have a hard time removing the tie rod ends from the rack as well so you will probably be going to a work table for that anyway.
