IvaTiger
I know that when rebuilding the front suspension that the fulcrum pins need torquing with the weight of the car on it . My question is does the same apply for the the bolts holding the fulcrum pins to the cross member and the upper / lower ball joints The sway bar will also be torqued with the car on the ground , guess I need the engine in the car as well before torquing Thanks for any advice
