260 Display Engine parts wanted.
Duke Mk1a
It is coming along nicely. Here is what I am still looking for -
Crank pulley
Remote oil filter assembly
C4DF 2V carb
Booster manifold vacuum fitting
Carb return spring
4 intake manifold bolts
Yellow top coil
Rubber line from carb spacer to PCV valve
PCV valve with clamps
Temperature sensor
TIA for any leads on these or availability.
Duke
Roger...I thought that was the case but was not quite sure.
All the Best in tracking those items down.
Lt,
What is the diff between C4AF-9510-CU, and the C4DF. The first is a search I have been following with zero results. I also am looking for an original carb so let me know if you double score.
Did you actually rebuild your engine block and heads or just make it look pretty?
Paul
Will do. When I pulled the 260, it was making 180 HP and ran like a dream. The pistons are .030 over and the heads rebuilt with larger chevy valves.
