This information was generated from discussion on the for sale area in regards to a distributor for sale. The discussion focuses on the "Z" designation in the Z5TF-12127 -C part number. I asked the Ford V8 guru Bob Mannel about it.
Here is his reply -
Duke,
I did a little more digging. As I mentioned in my book introduction, I stayed away from non-production applications of the Ford small block V8. Since the book has been published I have looked more at some of these other applications.
In the case of the Sunbeam Tiger, Ford continued to make 260 V8s for two more years after it concluded its 1964 production use of the engine. The Tigers got many updated parts for its 1965 and 1966 260 V8s. Contrary to convention, these 1965 and later engines were not leftover 1964 versions.
Casting number date codes continue to reflect actual manufacturing beyond
1964 production.
The letter Z was not related to the Tiger. Tiger-unique parts with Ford part numbers used a J in the third position. For example C4JZ is a Tiger part number. You will notice in my book on page D-5, the normal 260 distributors (C4OF-12127-A and C4OF-12127-B) were replaced by
1965 versions (C5JF-12127-C and C5JF-12127-B). These are Sunbeam Tiger engineering numbers (J in third position).
Digging deeper, I checked the cross-reference books which given part numbers their engineering number application. For distributors, this cross-reference has provide highly reliable.
C4OZ-12127-A is for a 260 V8 with manual transmission:
. C4OF-12127-A (used on 1964 production 260V V8s)
. C5JF-12127-C (shown as a 1965 replacement)
. Z5TF-12127-C (only shown in the OSI) C4OZ-12127-B is for a 260 V8 with automatic
. C4OF-12127-B (used on 1964 production 260V V8s)
. C5JF-12127-B (shown as a 1965 replacement)
Tigers all had 4-speeds. So, I am inclined to agree that the Z5TF-12127-C is exclusive to the Tiger, although I would not go so far as to say that that is why a Z was used as its first letter. Otherwise, there would not have been a Z5AF-12127-B distributor to replace the 289-4V C4ZF-12127-C distributor, an engine the Tiger never had or was intended to have.
Another thing to keep in mind is that Mexico began 260 V8 and 289 production in 1965 and ran through 1967. The 260 V8 was used in Mexican Falcons and light trucks. The 289 was used in B-600 and F600 trucks as well as Mexican Galaxies and Mustangs. So, it is possible (but I don't know) that the Z5TF distributor got its designation from the light trucks (T for truck) and the Z5AF from the Mexican Galaxie (A for Galaxie), and the Z is for Mexico. All just speculation.
Feel free to use any of this in your discussions on the Sunbeam forum.
Bob Mannel
Good information I did not want to be lost in the for sale section.
Here is his reply -
Duke,
1964 production.
Bob Mannel
