Hi All
Well I am just about at wits end trying to fix my passenger side brake lamp problem. You might recall from Part I that the passenger side brake lamp is noticeably dimmer than the drivers side and when I apply the brakes with the tail lamps on the entire passenger tail lamp goes dark. Here is what I have done so far.
1. Replaced the bulbs
2. Replaced the lower (tail/brake lamp) socket
3. Replaced the entire Tail Lamp Assembly with another assembly.
4. Ran separate ground wires from the lower stud secured by the wing nut to the bolt that secures the fuel tank to the body. I did this on the passenger and driver's side. I sanded down the areas where the grounds are located and used star washers to try and get good contact with the body.
After each of the above steps I tested the lamps and the result is exactly the same as described in the first paragaph.
At this I am out of ideas and have done all the things suggested by the members of this forum.
Help!!!!!!!!!!!!!!!
Help!!!!!!!!!!!!!!!
