I need to remove both the clutch and master cylinder for cleaning/rebuilding
and to clean up engine bay. Probably more to it then just unbolting from the firewall. Fluid is long gone My dash is not installed if that helps. Kevin
Thanks car is in trailer but did look and looks not difficult once brake pedal is disconnected remove spring and rod should go thru firewall once the 2 bolts are off. Clutch master looks the same. Kevin
