Crossmember bolt
Cameron Crockett
in process of putting my motor in I found that some previous hack had lost one of the crossmember bolts. Does anyone have one they could sell me? It would be greatly appreciated.
Ordinary Critters
First, poke around inside the X-member with your flexible magnet which is where they usually end up. Next, they are a standard Grade 8 bolt; 1/2" x 20 tpi (fine threaded) X 3-1/4" long. The threaded portion is 1-5/8" as is the shoulder length. Both the bolt and the fat washer can be had at any good hardware or Fastenall store. If you use a 3-1/2" bolt, make sure to turn the threads down to leave a 1-5/8" shoulder. amen
Hmm, I was pretty sure these are a British thread. Not quite the same as what we find at a hardware store.
bolt
there have been a lot of discussions over the years and they always end the same . many say the one seat bolt is supposed to be the only british thread on the car. ???????????????
