Dashboard lift-the-dot stud locations.
Duke Mk1a
Been asked a few times but I have never gotten measurements or pictures of the dash hole locations. I need this info to find the holes from the top of the dash with dash cover installed. Will then install the studs.
Really want to use my tonnaeu cover this year.
TIA for any help.
Stud location
Duke thanks for reminding me I put a new dash pad on some years ago
And forgot to put the studs in before installing windshield. My dash is out so I should be able to find the stud holes, are the studs the screw in type?
Sheet metal
Screws are the worst if you drive with a tonneau partially open the flogging pulls sheet metal screws out and then you are faced with putting a speed nut on back side when the hole gets widened.
