How difficult is removing and reinstallation of the window tracks, door latch, etc? Are there any special notes I should know before starting? I'm not looking forward to this. I have a feeling it's going to be a pain in the arse.
The very worst part is fitting the anti rattle strip and weatherstrip on the upper door onto the glass. Those bloody clips fall off to the bottom of the door just as you are lowering the seal into it. I have walked away after having it right, wind the glass up and down and the seal raises. I have tried glue as well![]()
I think we have all had this same problem with the window seal. I mentioned to Rick that IMHO the rubber material was way too stiff and pulls out of the clips when the window rolls up. I suggested that the rubber should instead be more pliable so that the seal bends out of the way. He agreed, but said he had just purchased a hundred pieces. That was several years ago, so maybe if enough of us contact him, he'll make a change on the next batch.
My two cents,
Spike
Why wouldn't you have got them from one of the UK suppliers? The repros for the window blade seals are wrong fit many cars, not just stiffness but also dimensionally. I would have thought you could get correct spec OEM seals from coh baines in the UK???It is of course a bit disappointing that I'm now stuck with them as the price and the postage over the pond is a killer.
Have a guess......
In all of the UK now dy has the external rubber blade seals.... In the words of J.P McEnroe " You can't be serious " .....
