Finishing touches
gtpzxtmike
I need a little help on a couple of things.
1. On a MKII lower grille moulding what can be used for the snaps/rivets that are attached to the upper section of the lower valance? (See attached photos) The photos are from a different MKII mine were missing.
2. What hose is being used for the drain tubes from the heater core and vents to the duck bill drains?
3. Below the dash pad and above the wood dash what is used in that area? I believe it was a black cardboard? Was it vinyl covered?
Any help would be appreciated.
I got these for the lower finisher from a supplier in the UK ...they work with a little adjustment. I have a bunch and also told Rick at S.S. about them so I believe he stocks them even though they don't show up in the catalog...
B382000446
Odds & Ends
#1: See Jim's comment. OR, use a 4/40 stainless machine screw w/washer and nut it snug from beneath.
#2: I use the molded PCV hose repros for the old Mustang SBF and trim it to drop in nicely.
#3: The center piece is black cardboard, but the two end pieces are vinyl covered metal. All are riveted in. Patterns can be copied easily from any donor Alpine.
Amen
Amen
The two end pieces are vinyl covered aluminum. I have a pair, may have the cardboard but not sure where I put it? If you can't find any pieces let me know. I'll need to dig through my storage unit.
P
