Gasket and intake less than fun
So...
As discussed, the rockers were hitting the baffles. So, the FelPro double cork with metal insert gaskets were test installed and this appears (will be putty checked) to provide clearance. Beefs I have with it; A: dern thick, B: Off-set from valve covers a bit. In fact , the VC themselves seem a bit offset, the overlap on the side is greater than that in the valley... Makes me pondering a swap to baffleless.
Duke, I do recall your PCV fix and you were so kind as to provide one, which I had planned on using, baffle or not.
Some of the gaskets overhang into valley from heads or IM, can you just razor cut those? Or paint to match is better?
And a new find, which frankly, I feel the shop should have caught...wth. Take a look at the intake to distributor opening. Overhang will have to be 'clearanced'. Certainly this would have been easier with the IM off, pre-sealing, no. Come on guys...
Fancy bolts, yay. And will have rear VC as allen key, thanks for that tip.
Anyway, moving closer to having a motor with no place to go. yet.
Derek
