Fuel sending unit - 67 Mk1A
67tntiger
I'm restoring my fuel tanks and would like to know what the olm meter should read from low to high. I have cleaned the the sending unit contacts with alcohol and Q-tip. I'm getting 34 olms low to 230 olms high.
Keep it Simple
Frankly, I prefer the shade tree/barnyahd method. Hot wire it thru the system(including the mini voltage reg), hold it steady and raise & lower the float. It will take a bit of patience as the gauge is slow to read, but it all works when correct.
