harmonic balancer
I am running the ceterforce flywheel, disk and clutch. The engine was originally externally 28 oz imballance with a flexplate for an auto. So I had the crank, HB, flywheel and clutch re balanced. Flywheel has index marks for the crank and pressure plate to keep it all smooth with R&R.
Duke I know your running a centerforce flywheel, but I'm no where near your Hp
so trying to find something in between stock and HP, same with the balancer
Just confused on what will work if I stray from stock specs. Thanks for any input. By the way what balancer are you running and is it a direct replacement.
Kevin
Kevin
It is a Summit Racing SFI balancer for a 289 - 351. Not sure about a 260.
http://www.summitracing.com/parts/sum-c4269
