hoses
rllance
New forum user
hello all. New to the forum and putting together my 66 Tiger after a 10yr restoration project...been doing it myself. I lost my pictures pre-disassembly during divorce so I need advice.
I need to know where the 2nd hose on the back of carb base plate goes? I know the left goes to the T off the heater hose, and the single outlet/inlet goes to the temp indicator then to the manifold. I'm just lost on this one.
Thanks for the help,
Roger
PCV Valve?
If my memory serves me, it hooks up to a hose coming off the top of the PCV valve stuck into the valve cover. I believe for Mk 1 and Mk 1A, there is a right angle adapter on top of the valve.
You can make sure that the nipple goes into air space under the carb and is not part of any water passage.
Guess we will if others confirm this or correct what I think.
Good luck in getting your Tiger back together.
