I NEED a softer/easier Clutch Pedal!
spmdr
Recently, there has been a search for a softer, lighter or easier clutch pedal.
The focus has been the Slave cylinder,
Only because, in the past, the 5/8" Master cylinder was the smallest size available.
Jay Laifman reports Wilwood now makes a 1/2" bore sized Master cylinder!
Part number 260-15088 is a remote reservoir Master cylinder that looks like it should bolt in.
With the change of Slave cylinder sizes from 7/8" to 1" there is a piston area change of 24%.
With the Master cylinder change from 5/8" to 1/2" there is a piston area change of 35%.
So now there is another avenue of change for a geriatric style clutch pedal....IF it works for you.
To take advantage of the different bore sizes, you NEED a clutch that engages near the top
of the pedal travel.
With the lighter effort comes more travel to do the same job.
DW
Thanks for the information. the 260-15088 would also need a remote fill reservoir installed. Wilwood has the compact intergral master cylinder, but, the smallest bore size is 5/8 (.62"). Do you have a part number or source for the 1" slave cylinder? Cliff
There are no known (to me) 1" bore slave cylinders that will bolt into a Tiger.
The process is to bore a Tiger slave to 1" and use a new piston and seal.
The popular 1" slave to use for internal parts is sold by Moss and used on a Triumph GT6.
the part number is 580-760.
BTW, that GT6 part will bolt into a Sunbeam Alpine.
And, at one time, the Alpine slave cylinder rebuild kit came with a new piston.
I have not checked the contents of recent rebuild kits.
DW
