Hi All
I was getting my Tiger ready for the season and I noticed that I was not getting a charge at idle. The more the car warmed up, the more rpms it needed to keep the ignition lite off. If you recall, I have posted about problems with keeping a voltage regulator for any great length of time. This time I did pretty well…it lasted over a year. I checked the battery and generator just to be sure…the battery had a full charge and the generator was generating.
So I switched out the v/reg for one I purchased from SS as a backup last year. I have done this installation a couple of times so I was confident, even with my minimal skills.
I got the new v/reg in. Reconnected the battery but When I went to polarize it (touch F wire and B wire momentarily per Shop Manual)…nothing. I checked my connections (Brown to Batt terminal…Brn/Grn to Fld terminal…Brn/Yel to Arm terminal) all were correct. I double checked battery…full charge.
Thinking the v/reg might be bad, I reinstalled the old one…same results…nothing.
I installed new one again…same results.
What happened? Any guidance? I double checked all the ground straps, cleaned them and reconnected them.
The only other action I took was to disconnect the terminals on the generator and cleaned them up. I checked to make sure I reconnected them correctly.
I took a chance and turned on the ignition…dead.
Help please!!!!!!!!!!!!!!!!
