Solid
response, because we need to up the detail here IMHO...
- Base ply and ply above battery is 1/4", 5 layer, with rounded (yes) corners.
- Battery box made with SOLID wood; 9/16" thick x 2 9/16" height. 19" x 10 3/4" are dimensions of battery box top lid.
- The solid wood forms a sandwich between the ply sheets, thus you cannot simply use the cutout from the box area as the lid. you'll need to have it be bigger by the width of the solid wood for overlap.
- Vinyl. There are vinyl sheets available from vendors such as S/S. I've yet to assess the quality of the grain match. I have seen covers over the side panels and this floor that are far to thick and grain which does not 100% match original pattern. (this is the case for some other re-pop vinyl areas as well I am finding...) This floor vinyl grain does seem to match the under dash 'knee roll' padding in texture FYI.
- Hardware: sorry, I wont be unscrewing any of these, as they're a bit rusty-ish and want them to stay where is. But hope the pictures can help.
- Simple flat woods screws into the box sandwich, staples to hold vinyl, and the nut/bolts holding straps, hangers look pretty standard. Should not be an issue.
- Strap = issue. Folks trying to repro the tool kit boot floor strap are challenged. I've an idea... Before I release that info, I'll try to confirm and determine if I could sell a few for pints or liters of petrol.
