Shifter rubber gator
Ok the gearshift boot has a trim ring. I need the size of the screws that attach the trim ring to the floor
Screws
Hi Steven, I can’t remember the name of the style of “philips”screw, I think it may be called an “oval or pan head “. If you hold the screw between your fingers, the head is slightly rounded on top with a chamfered head on the other side. They have a course sheet metal thread approximately 1” long. The width of the business end depends if your holes are stripped or not. Try some different sizes to suit your own needs.
Brian
