Some Pie Cutters
Cal44
Mod. notes dead link good follow on posts
The starting price has dropped $300 since the listing previously.. nice to see a set that still have the head caps on (often removed) I have heard these castings can be quite porus and let the air out of tyres.. I guess you could always have them sealed inside the rim.. or run tubes.
pie cutters
they're still 45 years old and could be very brittle. i wouldn't drive very hard with them.
TigerBlue
Old Aluminum Wheels
The Ad says "Mags" but the LAT - 9 wheel is aluminum. "Rim and spokes polished to mirror like finish" The wheels in the ad appear to have been sand? blasted and the polished high points appear the same flat grey.
Safety? Aluminum wheels are not as subject to aging and cracks as magnesium. But those old Goodrich tires are probably past their use by date. What would it cost to get the tires R & R'd when these wheels cannot have the tires changed using the conventional tools? Where or who would you do it?
This is the reason that lots of these had the head caps cut off them wasnt it? I believe that there are a few tyre places doing balancing now via laser measurement.. so that may fix the balancing issue.. as for fitting.. am sure it could be sorted out.
