May 1st Rantoul Ill . Taken at the midpoint of a standing start 1/2 mile race .Final speed 157mph. The Tiger 1st , Hellcat 2nd.
Is the current hp rating method the same as it's been since 1973, or have they changed it to something like the "peak hp"
I rode in a recent vintage Shelby Mustang this weekend that supposedly had 600 something hp, it didn't feel as fast as my Tiger which has considerably less, and I'm pretty sure I could beat it in a drag race.
Bob K.
B9471705
Hi Jim , The front suspension is a modified Hokenson . The rear is a 3 link coil over with a full floating 8.8 and 3.55 Torsen differential. The transmission is a T5 with an AMC tail housing. The transmission gear set is from G Force with a.82 5th gear ratio.. The engine has an aluminum block (Ford Racing ) with a zero balance Eagle crank and rods. The C.R. is 10.75 . The intake is an Edelbrock Air- Gap port matched and flow balanced. For fuel injection I use a F.A.S.T. throttle body and Big Stuff 3 ECU . I run CAT headers with a 2.5 in exhaust. With the hardtop installed and me in the car the weight is 2480 lbs. 49% front 51% rear.
