Stainless pivot for softop side cover
The stainless pivot that screws into the brass unit mounted in the B pillar and allows the side cover to fold up and down is broken off. It is flush with the brass unit and I cannot drill it out with standard drills. Any solutions ?
Carbide-Tipped Drill Bit
I haven't had to drill stainless steel myself, but understand that a carbide-tipped drill bit is better than the typical high speed steel bits and would likely work. I believe a lot more expensive solid carbide drill bit is better and is less likely to "walk" when trying to drill.
As I recall, the hole into which the pin screws does not go all the way through. So if you are drilling from the pin side and not the threaded side, won't the drill bit will be trying to tighten it even more? The other options takes little work - buy another brass unit for that side's B pillar.
Good Luck!
It's a PITA, BUT
A small center punch to keep the drill from walking off. Stainless is generally softer than steel screws and should drill easier. It's a patience thing.
