Steering shaft bracket bushing
67tiger
I think I've found a nice option to replace the rubber bushing that lines the the steering bracket inside the engine compartment. Gates part number is #26391 and it is a hose adaptor. it is a tight fit but found a little armorall was all that was needed to force it up the shaft. It's a much firmer rubber than you would find in a standard hose that you might use to create this piece.
