OK, I'm stumped and so will put it out for help from the more experienced.
Last year I bought B9471929. The car was formerly owned by Craig Angel and was extensively autocrossed. Like Warren said in an earlier post, race hard, wreck, repair, repeat. When I obtained it, it had been in storage for the better part of the past 10 years. PO had obviously done a lot of mechanical work on the car, and just as obviously had zero mechanical skill. I was going to completely restore it, but subsequently bought B9471705, which was a never wrecked, no rust car like I'd been searching for for years, and which I've already completely restored just how I want, so now I'm just trying to get B9471929 back on the road as a running, driving Tiger. I got most of the issues sorted out eventually, but one has me stumped.
The engine is a built 302, 6 bolt block. Runs great, white smokes both tires for a good 50 to 75 feet, feels like it's going to pull a wheelie when speed shifting into 2nd, and will break the tires loose just by stepping on the gas in 2nd. (granted, 10+ year old hard as a rock tires have less than ideal traction)When I got the car, both motor mounts were broken and the motor was sitting quite low. The oil pan had obviously been hit hard on something, and had a big dent in it. The first time I got the engine up to normal operating temperature, once it got good and warm, the oil pressure dropped down to about 5 psi at idle and 10 to 15 at 1500 rpm. Oil pressure was normal 30 to 40 at idle and 50 to 60 at 1500 rpm when cold. ( I did the above mentioned burnout about 2 minutes before noticing the oil pressure dropping drastically)
I dropped the oil pan, and discovered that the dent was pushing the bottom of the pan against the pickup, and the pickup bolts were quite loose. I pulled the bearings and they were right down to the copper on the bottom of the mains and top of the rods, with the slightest hint of tin remaining on the opposite sides. The crank was .010/.010, still in good shape with no scoring or marks, and mic'd within tolerance. Bearings were .010/.010 as well. I noticed that some of the rods were installed backwards (chamfer side to the center), and a couple had the caps backwards on the rods. I couldn't get the rods to pivot without dropping the crank, which I was reluctant to do (and is probably impossible with the engine and trans in the car) and so I left the backwards rods the way they were, I didn't notice any scoring on the outer radius of the crank journal so they must have still had just barely enough clearance.
I put in a new set of .010/.010 bearings, checked the clearences with plastigage, all within tolerances, installed a new high volume/high pressure oil pump, new pick up screen, new heavy duty pump driveshaft, red loctite on the screen and pump screws, new oil pan. Put everything back together with a fresh filter and fresh 20/50 oil, started it up, warmed it up, and..... exact same symptoms. Except that now the high oil pressure when it's cold is more like 80 PSI and it drops to 20 when hot. Valves seem to be adjusted within tolerances and it runs perfect except for the oil pressure problem. Yes, I checked to make sure the oil was going the right direction through the aftermarket adaptor and remote filter.
Any Ideas? Short of removing the motor and doing a complete overhaul? And even then I'd like to have SOME idea of what I was looking for.
Bob Knight
B9471705
B9471929
Bob Knight
B9471705
B9471929
