Sunbeam Tiger Positraction Limited Slip Unit
Maliburevue
Correct positraction unit for all Sunbeam Tigers. This unit accommodates 2.72, 2.88, 3.07, 3.23, 3.31, 3.54 and 3.73 gear ratios. It has been disassembled, cleaned, inspected and rebuilt with brand new factory clutch kit, 22233X, for the street setup. The posi is pre-lubed with limited-slip oil, torqued and ready to install.
There are 2 bolt sizes for Tiger ring gears, 3/8" and 7/16". I can set up this unit for either size. Most Tigers came from the factory with 2.88 gears and 7/16" ring gear bolts, however, I suggest you remove the rear cover (drain the oil first) and remove one of the ring gear bolts to confirm.
$450 + shipping and insurance. Will ship international.
SOLD!!!
