My Tiger has seemed to defy conventional wisdom for years. For decades, I would have to pull the filler neck back on the nozzle in order to put gas in my Tiger. I found a small crack in the overflow hose connecting the 2 tanks and fixed it. Ever since, all I have to do is put the nozzle in, set the catch, and wait for it to fill up- and it shuts off automatically when full. Then, there was case of grinding gears in my transmission when the car was in NEUTRAL and I would depress the clutch pedal. Wobble. The latest incident, however, takes the cake. Ever since I’ve owned this Tiger (35 years now), the tach has never been accurate, nor has it gone beyond 2500 RPM’s. I checked several things; the loop, anything that might be binding, etc. It is worth noting that I have a factory mechanical dual point distributor, stock ignition, except for the hotter Petronix coil I put in a couple of decades ago. I even tried one of the new tachs with solid state internals, and it was not accurate, either. Flash forward to today, I changed the points and the rotor- the cap was good, as was the capacitor, just like I have a dozen times before, and went for a test drive. The tach is now working!! Huh?!? I’d never seen 5K RPM’s before today, let alone 4K or 3K! I’m waiting for William Shatner to step into my garage and put me on “The Unexplained”…
