Yes Gary I did the same thing to my car but had to weld new spring perch up front.
I'm not a big fan of big burn outs on the street just shows you can't get it to the ground.
My car will actually pull the front wheels off the ground on the street with my Hoosier QTP 26x9.5x15 tires.
And will run 9'40's @148 and can drive it to and from the track on pump gas.
Car is getting a full cage installed and will be going to try and get certed to 8:50
The young man that is doing it has been doing a great job and I'm sure it will cert.
Having to motor rebuilt and hoping to put 16-18 lbs of boost and make 800 RWHP and go 8:90's@ around 155.
It will have removable side bars so my wife and can still take it to church and out for dinner !!!!!
Pics please Jerry.
How much power is that at the flywheel?
Do you have the details of you set up. Engine, capacity etc?
Thank you.
Wish I could post pictures !
Motor is a WorldProducts 370 ci with 225 AFR HEADS
And about 14lbs of boost with twin 57's turbos.
I would say close to 950 to the flywheel, new setup will be over 1000
And still very streetable new technology is great
