An abundance of patience to install.
In addition the wherewithal to replace the plastic line that you can't get to for the oil pressure gauge unless you remove the filter. Then there's buying a big giant 36 mm wrench cutting it in half to make it so you could put it on the big bolt on the top and a smaller one for the line to the hose. But of course that was after I bought a inch and 7/16 BFW as advised by one of my homies that sent me a picture of his cut up wrench. I ended up having to buy a 36 mm one because it just fits so much better. As I understand it there's two different nut sizes probably because they used two different vendors or more during the production.
