Dan Walters authored this year's Tiger Quiz.
The winners were Terry Taylor, Tom Hall and Peter Phelps.
Not much of a surprise there.
1) What year did a Sunbeam Tiger set the World land speed record at Daytona? 1927
2) What was the record speed? 203.79
3) What was the retail price of a Sunbeam Tiger MKII? $3,842
Based on the Rootes Sunbeam, Chrysler Motors Certified Car Care Warranty Required Services Record, answer the following:
4) What was the general Warranty coverage? 12 months or 12K miles
5) What was the Drive Train Warranty coverage? 24 months or 24K miles
6) What was the oil change interval? 3 months or 4K miles
7) What was the oil filter change interval 6 months or 8K miles
8) What was the recommended Tire rotation mileage? 8K miles
9) What was the recommended engine performance evaluation mileage? 8K miles
10) What was the recommended Brake inspection mileage? 12K miles
11) Could you tow a trailer with your Tiger? Yes
12) Was your warranty transferable? Yes
Based on the Sunbeam 260 Owners Handbook, answer the following:
13) Above what speed do you increase tire pressure? 110 MPH
14) What feature is built into the turn signal indicator? Dimmer
15) What feature is located in front and above the glove box? Map Light
16) What engine RPM "MUST NOT BE EXCEEDED"? 5K
17) What engine RPM for checking oil pressure? 2kRPM
18) What is the summer cooling system thermostat temperature? 160 deg F
19) How many filters need attention? 4: oil, fuel, air & booster
20 Under the Steering and Suspension section, there are 5 items that are noted for "particular attention" for checking bolt tightness. Name one.
Lower Fulcrum, FT Crossmember, rear U bolts, shocks, anti-roll bar
