Tom Hall T-5 transmssion
Moondoggie
Up For sale is my Tom Hall T-5 5 speed transmission. It is complete less
adapter plate which are readly available from Tom Hall for $150.00. This transmission will cost you $4800 +++ from Tom but I am making this one available for $2500 or best offer. It will need some repairs since it has a whine in 3rd gear but other than that it is fine. A reasonable estimate of repair cost is less than $1000.
Moondoggie
You will need to buy the adapter plate for a five bolt or six bolt
bellhousing depending on which one you are using. These are available from Tiger Engineering for $150. Other than that you would likely need a new clutch
such as a center force unit. The transmission itself will need mainshaft bearings, third gear blocking rings and syncro's and perhaps a set of third gears. A good transmission shop could eastly do the work for less than the estimate I posted. Here is a link to the installation instructions :
http://tigerengineering.net/T-5 Pics/Transmission assembly/T5 Tiger Installation watermark.pdf
Moondoggie
