standard exhausts in stainless steel are available from Sunbeam Specialties. If you want a larger diameter any exhaust shop should be able to make the pipes up. I had mine done locally in 2" and the cost was reasonable.I have a 67 MK1. I need an exhaust system
Also looking for 15" Panosport style wheels
Andy
215-514-5812
Andy, what's the VIN of your Tiger . I'm assuming it's a B3820 ....I have a 67 MK1. I need an exhaust system
Andy
When I had my system made, I directed the muffler shop to "oval" the exhaust pipe where it passes through the opening in the frame. That has zero effect of causing any added backpressureIf you have a muffler shop fab and install an exhaust system on your Tiger, make sure they don't simply "enlarge" the passthroughs in the frames. I have seen parts of the frame removed, making the frame weaker.
