I will be posting updates from time to time. I'm lucky that my favorite nephew is a body and paint guru. Hope to keep it in budget!!Looks like you have a real job on your hands. I have seen much worse starting positions, but there is a lot of work ahead of you. I look forward to seeing photos and hearing about your progress as you return this car back to the road.
David
Looks the same as mine. B382001786LRXFE. Late 1a built in March, 1966.Spread mount tranny in a MK 1A ??
Yup!Looks the same as mine. B382001786LRXFE. Late 1a built in March, 1966.
That would be a wide ratio case.... Mk2 only (HEH-CF). You can fit one on a 260, or a 5 bolt 289 but you need a dual pattern bellhousing which are getting increasingly hard to come by. All Mk1/Mk1a gearboxes were close ration and narrow case/bolt pattern type. Of course... looking at the engine, that's a cast iron water pump, and 260 engines had aluminum pumps. It's difficult to say whether it's a 289 or a 302 without looking at the casting numbers or how many bolts hold on the bellhousing. Not that I am a purist... I have a 302 block with hipo 289 heads...
this should be a 65-68 289 with 6 bolt bell housingEngine stamp #s.
