I have lowered the price for this awesome Tiger to 40K firm! As stated earlier, included with the deal is all the interior parts to finish, and the extra parts I have in boxes around the garage. Including light rings, wiring harnesses, extra window parts, traction bars, rear springs, soft top frame, restored hard top, and misc original parts that were upgraded.
The process and photo's are all on the web: http://loveallphoto.com/tiger
The "spec" sheet is as follows with all the receipts for the work. You won't find a better deal for the money...choose to go with the "kit" interior black for around $1800, OR do a custom buckskin leather (that's what I was going to do) for around $3500.
Not a single disappointment with this car!
Thanks for looking! Call me! David Loveall 541.345.9900
OR EMAIL at: david@loveallphoto.com
1965 Sunbeam Tiger Mk1 serial #1502 spec sheet:
--Bought from Barry Schnitzer, Corvallis Oregon in a box and
disassembled, primer rolling chassis
--Painted 2000 Porsche Speed Yellow
--Undercoated with POR-15
--Ford 289 V-8 motor, rebuilt .0030 overbore
--CAM specs at CL-951PK 5º ATC, 44º BBC
--Transmission 4-speed Top-Loader re-sealed, performance tested and recertified by AAMCO Eugene, OR
--CAT (California Association of Tigers) headers, ceramic coated inside and out.
--Dual 2 ¼ inch exhaust, Frame ducted, Turbo muffers
--Coil, 1-wire 60AMP Alternator conversion
--All new wiring harness
--New Walnut replica dash, gauges rebuilt
--New Master Cylinder, Clutch Slave Cylinder, Water pump
--New brakes front/rear
--Rebuilt window gearing and channels
--New door panels, (uninstalled, with clips, screws etc)
--New shifter boot, hoses, rubber grommets, drain hoses
--Original aluminum Hardtop, new seals, restored
--New CAT tiger racing leaf springs designed by Dale Aukwsweki, Dale’s Restorations, San Bernardino, one of the premier Tiger men in the country.
--CAT Tiger valve covers, powder coated silver
--Rebuilt heater, new valve
--All new rubber throughout the car
--Stainless steel fasteners, nuts and bolts throughout
--Brake Servo 5” rebuilt
--K & N filter set up
--Mallory electronic ignition
--Limited Slip Differential rebuilt Hwy performance ratio 3:07
powder coated finish
--Steering rack rebuilt, powdercoated
--Edelbrock Performer Carb 600CFM electric choke
--Edelbrock Performer aluminum cylinder heads
--Holly/Weiand Action Plus aluminum Manifold, powder coated silver
--Front cross member rebuilt for correct Ackerman Angle and reinforced at the weak Factor area. NEW steering Arms/Tie Rods
--1” sway bar front, 5/8 heavy sway bar rear
--CAT Koni shocks
--Panasport rims 7inch front, 7 ½ in rear
--New lamps, covers, speedo cables, SUNBEAM letters, Badges
--Gas Tanks re-tumbled and painted
--Optima hi-power battery
--High output starter
--CAT Koni shocks
