TigerBob86
SOLD - '65 Tiger race/street - SOLD
- SOLD -
SN #B9471388
TAC #0616
Close ratio toploader just rebuilt.
Engine ( approximately 3000 miles )
professionally built 347, dyno'd at 415HP at the flywheel, hydraulic roller cam, Dart Pro-1 aluminum heads
Edelbrock RPM Air Gap manifold, MSD 6AL ignition and billet distributer
Custom 650cfm vacuum secondary carb with mini annular boosters by EPS (http://www.eps-hane.com/).
Aviaid Road race 8 qt oil pan
Parts from Dale's restorations ( http://www.dalesresto.com/ )
- Wilwood disc brakes 12.5" front and 10" rear
- Stainless brake lines
- Reinforced and powdercoated front cross member
- Adjustable front swaybar
- Reinforced and powdercoated upper and lower A-arms
- bulletproof fulcrum pins
- 650 lb front springs
- rear leaf springs (extra leaf forward of axle)
Dana 44 (approximately 3000 miles) Auburn posi, 3.31 gear ratio
FIA roll cage from Custom Cages in the UK, professionally fitted and welded by local rally cage builder.
Fluidine aluminum radiator
Panasport 16x7 wheels
22 Gal ATL fuel cell (07)
Aeromotive A1000 fuel pump/fuel pressure regulator/fuel filter
All Aeroquip stainless braided fuel lines and oil lines.
Wilwood dual master cylinder
Koni single adjustable shocks front and rear.
hurst competition plus shifter
Painless wiring harness
CAT club ceramic coated headers
Centerforce II clutch/pressure plate
All Autometer electric gauges (speedo, tach, oil temp, oil pressure, water temp, volt, fuel level)
New belts (2011)
Kirkey seat
Halon fire system
Clean Colorado title, registration, and emissions
bobdixon at frii dot com
http://s1108.photobucket.com/albums/h407/TigerBob86/
- SOLD -
SN #B9471388
TAC #0616
New belts (2011)
Kirkey seat
Halon fire system
