Bellhousing
TigerBob86
I'm curious what people are using these days to bolt up a 6-bolt block to a narrow toploader?
Thanks,
Bob
Forrest39
Bob,
Other than aftermarket scatter shields, there are a few options. There is a Ford one that needs a few holes and reinforcing. I picked one up on eBay last year for $125. I can dig up the part number if you are interested.
-Kevin
Forrest39
Bob,
The part number is listed on David Kee's website for 1965-1967 289's. The part number is C5DA-6394-A.
Hope this helps.
-Kevin
Bell Conversion
Here's the 6 bolt bell housing conversion we do for the narrow case HEHE. It involves adding aluminum inside to locate the needed bolt holes. Drilling and tapping is pretty straight forward using the case as a template. Just make sure that the nose bearing retainer matches the center bell hole size for proper centering.
gregory schumacher
Bell housing
Bob I have a six bolt bell housing modified to also fit a tremic tko transmission media blasted and clear powder coated for sale. Have bolted both my top loader and TKO to it. PM if interested. Greg
TigerBob86
Thanks for all the great responses. On a previous Tiger I had an aluminum bellhousing that was narrow toploader to 6 bolt. I actually had a spare also. I didn't realize how rare they were at the time.
Dual pattern
Seen several on eBay but that's when I looked daily. They've @#$&+- it up as now you keyword Sunbeam and get everything that seller say fits Sunbeam.
I'm pretty sure that is a Trans-Dapt piece. It kind of looks like they had a design with a 'front' mold and a 'rear' mold that mated in the middle, and (assuming they made things match) this would allow them to economically make lots of different things fit, without spending a lot of money on unique casting tooling.
I have an old Lakewood scattershield for sale. Used it my Tiger for years and have now gone to a T5 box so no longer needed
It is a very tight fit in a Tiger and some cars require a bit of clearancing at the firewall or clipping the corners of the bell.
PM me if intrested
canbeam
If memory serves, and I'm talking early 70's, I believe I used an 8 hole bellhousing from an Econoline van when I took out my 260 and replaced it with a 6 bolt 289. Probably pretty hard to find one of those now....
