Tiger and Alpine caster angle is set by the aluminium wedge between the front crossmember and frame rails. If I understand correctly, this is +3.84 degrees with the car at a level stance
I am about to make some of these shims caster shims and it is a simple matter to make the rear wedge pad thicker to increase caster to 5-6 degrees, without causing alignment problems at the rear bolt.
What is the collective experience on an optimal caster angle for a street Tiger?
