KettleCarver
I did a search, but I could not find any instructions on how to properly install the door cards. I got the panels, clips and little cups from Sunbeam Specialties. I also obtained and wrapped the upper padded area.
This is on a '66 Mk1a.
It looks like the upper padded piece slides over the top edge of the door, and then held on with 3-4 screws. There are 12 little plastic cups, 6 per door I assume. The plastic cups do not fit into any of the holes. Where do they go? Are the spring clips supposed to go into the plastic cups?
Is there supposed to be a vapor barrier between the door card and the steel of the door? If so, what kind of material and how is it held on?
If you have a description of the installation procedure, I would greatly appreciate it, thanks.
