There are some bad repo pins reported out there. Over machining of slots for attachment bolts weakening the pin as I recall. So it depends on who does them. Also stronger, better steel is very desirable. If you decide to keep what you have, at least get them magnafluxed and especially look for cracks where the threaded ends stop. I am sure there are several more knowledgable folks that can speak to this topic.
I would say have them tested for Rockwell hardness. You may already have upgraded pins. With that number handy, give Doug Jennings a call. Doug is in Ohio. In the past he has been able to source upgraded, much stronger steel pins. He will know from the Rockwell hardness number what you have. If you do not have Doug's phone number, let me know and I will PM it to you. FYI, Doug does not use e-mail but is very generous with his time over the phone, at least to those that don't waste his!
Also ask him if there are any specialists close to you he might recommend. BTW, I took off my A-arms and took my wife's car and drove to Ohio to get his help in installing my urethane bushings and ball joints several years ago. Which reminds me, do not forget to reinforce the upper ball joint mounting hole, if by chance that has not come up in other discussions!
Cheers, Gene
