9 gauge wire is adequate
Hope the wing nut doesn't hit the hood. My Black car had an obvious repair on its steel hood underside and I have seen more than one owner change something and drop the hood and bang!
I know its still ruff and in a plain white wrapper still but it's never fun creating more dents and not much fun taking them out.
I did redraw dukes bracket. I'm not sure of his original alternator dimensions, but I redrew according to my GT40 heads (same bolt pattern as the 260 head, but there are varying bolt sizes from 1964 thru 1997) and a new 93mm Denso Mini Alternator (3 wire) with 40a output. The alternator was ordered on Amazon for $71.49 and supposedly good for a street rod or race car. The alternator should arrive on Friday, Jan. 2nd. I'll continue to "mock up" using my paper template, then order some 1/2" 6061-T651 aluminum plate to be cut on the band saw and drilled on the drill press to make the final mounting plates. Then it is just cutting the right spacers to line up the V-belts using a laser level. Anybody have any suggestions as to what material (and source) to use for the spacers? The wiring should be straight forward and the 3-wire configuration will allow using the stock "ignition" light on the dash. Did I miss anything? plus, keeping the alternator down to a 40 amp unit should allow using the original 12v hot lead from the alternator.
I have a few pics of the setup that I took before I sent it to Duke if it helps at all... One of the reasons that I made it in 2 pieces was that I had some 1/2" X 4" flat bar kicking around and I managed to get both pieces out of that
If you go down to your local machine shop, they may have some chunks laying around...buying plate sounds $$$ I like working with aluminum as it easy to work.... some alum. round stock makes great spacers... I have a lathe so it was easy to fab... that adjustment slot was a PITA though... lol
I like the 3-wire setup better than a one wire... even a one wire can be converted as most cases are used for multiple apps and your local electrical 'guru' should be able to match up some 3-wire 'guts' for it. I've also seen the Densos anywhere from 40 to 100 amps
After the brackets are cut and cleaned up, a nice way to finish them off is a router with a 1/8" round over bit
oh... ya, there IS a spacer between the bottom 'ear' and the bracket... seems to me if the top 'ear' is bolted to the 'tensioner' bracket ( metric thread ), then it's about and inch from the bottom 'ear to the lower bracket. A little fine tuning might be required to get exact line-up with the water pump and damper pulleys... All this from 5+ year foggy memory
B382ooo446
Hey Jim,
What are you using there for your dual brake upgrade?
I know I am straying further away from alternators but the metals is on my list. Thanks for posting the link!
I just hate the LAT option scoop screen with the alloy expanded metal, looks like the stuff they sell at Home Depot and fixing it to the hood with gobs of silicone seal while period correct is ____.
Working on a perforated metal hood scoop screen wish I could get a stamping like the V-8 on the Stellings air cleaner.
