The stock pedal assembly uses a felt washer as a spacer between the pedal box and pedal arm pivot surface that needs to be periodically oiled to assist pedal return. The PO clearly did not know or care, and my felts are no more.
Surely there is a better way? A Torrington bearing would be nice
Failing an improvement, any suggestions for a source of the felt washers?
