Those that have removed the carb heater, have you relocated the temperature sensor? With the carb heater removed, there is no constant flow to the stock sensor location if the heater valve is closed so it seems to get an accurate temperature the sensor should be moved to a location with continuous flow. TIA.
Tom
9473100
Tom
9473100
