Upper and lower ball joint torque
pfreen
Does anyone have a recommendation for the upper and lower tapered ball joint torques.
I can't seem to find it in the manual that makes sense, The manual list the lower as highr than the upper, which does not make sense due to their size.
IvaTiger
Lower 33 foot pounds
Upper 52 foot pounds
Both specs are listed the same in 2 different manuals. I was also curious why the smaller upper joint has a higher spec , but I went with the torques they specified
IvaTiger
My manual lists the lower ball joint LOWER than the top
IvaTiger
IvaTiger
I know the bottom joint has a clevis pin and you have to fudge with the torque to get the pin in. I can’t recall weather the top joint has a pin or not , I am thinking it does not and I think because of no pin that justifies the higher torque.
As I recall I had to tap on the upper joint to seat the taper because initially the ball joint turned in the taper. It does not take much of a hit with a soft hammer
pfreen
My replacement lower ball joint is a nylock, so I will calculate a torque. I forgot the original had a castle nut and cotter pin, thus the low torque.
Thanks!
IvaTiger
Thanks!
I replaced mine but I still went with castle nut and cotter pin. Maybe if you go with a higher torque you may have extreme difficulty if you need to separate it.
