Wilwood kit measurement required
Rather than reinvent a bracket, I would like to use a Wilwood radial caliper mount bracket for a big brake mod I am planning.
Can anyone please give me a measurement from the spindle outer face to rotor centreline on the Wilwood brake kit.
Or spindle outer face to rotor inner face if easier to measure.
Spindle flange thickness at the bracket attachment point
This should help.
That is the instruction that I was referring to and all there is is a wheel clearance drawing
What I am after will take someone to physically measure their set up:
Spindle outer face to rotor centreline or spindle outer face to rotor inner face if easier to measure.
tigerracer
Not sure what you are planning but, the caliper and mounting bracket in the Wilwood Tiger brake kit is radial mount. If you are planning on a larger diameter rotor than 11.75" you would just need longer studs and spacers for the caliper mounting bracket.
