260 timing chain cover
I have a rotted out aluminium timing chain cover on the original 260 PN C4AE-6059-B and looking for a new one
All I can find is a Scott Drake repo C4AZ-6019-A or equally rotted originals
Anyone know of a repo?
Not a deal breaker if the Scott Drake part is all that I can find, and is dimensionally and cosmetically identical, but original is a bit nicer
Is the difference in how the road draft tube hole is plugged?
What is the difference in a C4AZ-6019-A and B?
When did the rib count change?
Have one
in my parts bin. I have to assume it came off the orig. 260 that is long gone.
In good shape. marked 65 C40E-6059A Sheffield
Anyone know the differences between 6059-A and B suffixes?
What is the difference between C4AZ-6019 and C4AE-6059?
And more number confusion:
What is the difference between my C4AE-6059-B and JBCAt's C40E-6059A
Found this on the Autox forum fwiw
The C4OE-6059-A timing cover casting is dimensionally the same as
the C4AE-6059-B and any earlier castings. The only difference is
C4OE-6059-A has the oil fill tube section totally removed from the casting.
I believe the C4OE-6059-A casting is what I have on my 66 MK 1A Tiger and it
is 2 3/8" thick. Unfortunately I can't see that casting number with it in
the car.
These timing covers are interchangeable with one note; the
C4OE-6059-A casting can only be used on earlier engine blocks if the oil
passage into the lifter gallery is plugged. You do have a freeze plug or
it is cast closed at the top passenger side of your timing cover casting
right?
The timing cover casting changed in June 1965 to go along with the
cast iron water pump. This timing cover casting C5OE-6059-A1 and later
castings are quickly identified by the 7 ribs between the water pump face
and the engine face. The C4OE-6059-A casting and earlier castings only
have 2 ribs.
morphed into part number decode
I thought I understand the Ford part number decode:
http://www.fordification.com/tech/partnumbers_overview.htm
C = 1960's
4 = 1964
A = Galaxie or Generic on my MK1 while your O = Fairlane
6059 = timing chain cover ???
B = 1st design change, A = original design
The part I do not understand is why the Scott Drake repo has a 6019 part number
C = 1960's
4 = 1964
A = Galaxie or generic
Z = service part
6019 ????
A = original design
In any case this explains it and revolves around the oil filler tube or lack thereof:
https://books.google.co.th/books?id=Zn-oCgAAQBAJ&pg=PA87&lpg=PA87&dq=timing+cover+C4AZ-6019-A&source=bl&ots=zLS_fo6bvs&sig=ZJ9_nzLET1h87qF1E9N9L4sVBZw&hl=en&sa=X&ved=0ahUKEwiAuOX01MLMAhVHI8AKHQE4Ds0Q6AEIUTAL#v=onepage&q=timing%20cover%20C4AZ-6019-A&f=false
Quote; The part I do not understand is why the Scott Drake repo has a 6019 part number.
I've seen a lot of after market suppliers use the original part number and add/change a number or letter.
Oops
I posted a part for sale and made the mistake of not inspecting it closely enough. :( It had been modified (not sure why) and I mistakenly thought it was just somebody's casting flash clean up.
Lesson learned!
Sorry for getting the hopes up for those that contacted me.
