Thanks for the responses and discussions. I plan on running a Derale 6 blade fan, Hoghead's pulley, Edelbrock water pump plus I modified the shroud to force the fan to pull air through the radiator, not around it. I also put louvres in the corners of the hood that I hope will be functional and not just pretty. They should accomplish the same thing as the LAT vents. I may try the horn hole block offs but will run this combination first.
This was my daily driver many years ago and I am all too familiar with popping the hood latch when that temperature needle started to climb.
I started this asking about aluminum radiators but may have been convinced otherwise. I will look into having my original recored with a dimpled version. The last time I had it recored 30+ years ago, the shop said that the tanks were showing their age and might not be able to handle another recore. I can attempt it again and see if we can pull it off one more time.
Question for Austin Healer: You run the smaller pulley but advise against a high flow water pump. I understand wanting to have the water not rush through the radiator but aren't these two things accomplishing the same thing - more water flow?
