AMC T5
1965_Tiger
I am selling a AMC T5 i bought a few years ago that i am not using.
I am looking for $600 plus shipping.
Paul
1965_Tiger
No i am not sure. I can check it out. I think it is a non WC trans that the case can be put on a WC trans.
Paul
The gears are pretty much the same as a new T-5 -Z as far as ratios but are pretty week @ 265 ft.lbs... gears are 2.95 1st,194 2nd,134 3rd,1.00 4th and .63 overdrive
Using the T-5z and the tailhousing and shift rail from the AMC , you can make pretty much unbreakable trans as that one is rated at 330 ft.lb.
Pretty budget swap if you can DIY the bracket for the trans and a couple other things compared to the TKO 600 kits. I've done a few and even managed to adapt the AMC speedo setup using 'stock parts'
The standard adapter plate puts the shifter a little more to the right which gives you more 'knee' room but need to cut a little bit from the hole in the tunnel.
spmdr
IF the AMC T5 is original, it should have ratios of: 4.03 1st, 2.37 2nd, 1.49 3rd, 1.0 4th and a .86 5th
DW
