Brake Light Switch Replacement
KenF
One of the connectors is broke on my brake light switch. I saw somewhere where this one might work? Thanks.
https://mossmotors.com/switch-brake-lights-lucar-terminals-tapered-pipe-thread
Wow too weird
I just had my hands on one. Even when they haven't been sitting for a long time they seem to go bad.
Our friends at Sunbeam Specialties sold me one, but if you want to shop by Price I'd happily send you the part number..
It's a Lucas product and seems to look like the old one except for the new bright finish. Maybe you want to price shop it.
If you do look up their clamp for the brake booster hose maybe you can order one of those and see what it looks like in person is a reasonable facsimile for the stock sardine clamp the booster
The big hex nut on S.S. one is 22 mm and its p/n is SPB401 . I have a larger switch installed unsure which size would be correct. Sent a email to you with add'l comments.
Thanks. I got some info from Chris, Moss one has wrong threads, should be 3/8 UNF. Like this one. Ordered one from across the pond.
It Ain't that hard
Any make/break pressure switch will work. The 3/8" X 24 tpi is the deciding screw in factor for any of them. In a pinch, I've thread chased one that had pipe threads. It's still out there functioning fine.
