Installed a new carb today....
Holy cow - what a difference...
WOT I am seeing 13.6 with the vacuum secondary open.
cruise at 2600 RPM at 70, 17.8 - 18.2.
And here's the ancillary benefit -- while rigging the throttle cable, I discovered a bolt that was WAY too long that attaches the lower left side of the heater assembly to the car. It accidentally acted as a max open throttle stop. I found that I was only getting 3/4 WOT before. After replacing the bolt with the correct shorter one, I now have full travel of the throttle.
The womp-um is just amazing, and I'm sure my fuel economy will be vastly improved now too!
One concern I have now -- and please chime in -- at low cruise (55mph) I'm seeing AFR of roughly 20:1. The power is way back obviously but is this too lean? Should I fatten it up a stitch?
Cheers, -Kevin
