Wanted Complete MK1 or MK1a Dash
There are accurate new dashes out there from several vendors, any original dash is almost guaranteed to need re veneering , do you have a dash at all? If you wanted to make one you can do that too, templates are available
I know you can get new panels, but what I would like to find is gauges with dash harness to make my life a little easier. I'm converting a race car back to street and nothing factory is their.
The wanting gauges and wiring harness is a "complete dash with accessories" ... The gauges for fuel, water, amps are the same as alpine s3/IV. The oil gauge is the same but with different rear fitting which you can get an adaptor.
Tach and speedo you could get the reworked alpine ones from thevguy making new faces , might be easier than getting original tiger gauges and they will be fresh rebuilds.
As for wiring, if going from race to street probably safer and easier to get a whole new harness either to original spec or one of Paul's upgraded modern setups.
Otherwise I think reword the ad to ask for complete tiger gauge set
